Re: 706 Steering Wheel Won't Move
Posted by JustCallSaul on October 20, 2013 at 07:41:47 from (64.141.35.91):
In Reply to: 706 Steering Wheel Won't Move posted by JustCallSaul on October 19, 2013 at 05:08:52:
Thanks for all your advice. The other hydraulics were fine which was why I was confused. Usually the steering wheel has "soft play" in it even when the tractors not on, and in this case it wasn't budging at all, the way some cars steering wheels sometimes lock up and you have to play around with them until they are free. Anyway... I took off the console cover to see if I could see what was going on, played with the wheel, started it up again, played with the wheel again, and suddenly it came free. I don't have a clue what happened, but it works! Thanks again for your suggestions. I will have to keep this forum bookmarked since there is always something to tinker with on the ole girl.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
