Re: Antifreeze in oil Farmall H
Posted by Dennis K (WA) on October 20, 2013 at 10:21:23 from (24.21.78.195):
In Reply to: Antifreeze in oil Farmall H posted by Aaron Halfmann on October 20, 2013 at 05:07:37:
Won't be sleeve seals as stated, H has dry sleeves.
Some H blocks have a soft plug in the front of the block behind the timing gear plate which can rust out and allow coolant into the oil.
Drop the pan, pressurize the cooling system and watch for where the coolant is coming from. If the soft plug is leaking it will drip off of the front main bearing cap.
Head, head gasket or cracks are other possibilities.
Good luck
Dennis
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
