Re: 300 Utility rear axle bearing help
Posted by HydroTek on October 20, 2013 at 10:29:57 from (69.27.61.74):
In Reply to: 300 Utility rear axle bearing help posted by bmagee on October 20, 2013 at 08:42:22:
the hub should slide right off, then remove the bearing cap
..if you need to completely remove the axle, remove the PTO first then remove the inner axle bolt ..you can then remove the complete axle housing
