Re: SH won't start
Posted by Janicholson on October 20, 2013 at 12:25:56 from (74.60.94.18):
In Reply to: SH won't start posted by VA Gasman on October 19, 2013 at 20:19:01:
Put a different coil on it (easy and if you have one it is free) if it runs then, you know the coil has gone to the recycling bin. They do die like that. a second check is to take the coil wire and hold it with a dry wooden or plastic cloths pin about 1/4" from the block. If no fire there, I would go with the coil swap. A 6v coil will work with the resistor, a 12v for use with an external resistor is also fine with the resistor. A 12 volt coil with no resistor required is ok if you bypass the resistor with a jumper. Jim
Today's Featured Article - On the Road with Dave Gohl: Tractors and Farming - by Dave Gohl. I never thought I'd live to see the day, when I could call myself a farmer. What allows me to say this? Well, when our family moved to our 20 acre site near New Prague, Minnesota, I had one thought in mind. You guessed it, farm it somehow. A little history is in order. In my younger days, mom, dad and my brother made frequent visits to dad's youngest brother Pete, who took over the home farm from grandpa MIke. It was the typical set-up, milk cows, pigs & chickens. In the winter, we'd play ... [Read Article]
