Re: 1967 farmall cub low boy h
Posted by mkirsch on October 21, 2013 at 05:47:13 from (64.80.110.75):
In Reply to: 1967 farmall cub low boy h posted by Jack in ga on October 20, 2013 at 18:32:06:
What problem are you trying to "adjust fix"?
There are actually two clutch adjustments. One is the pedal free travel, which the guys have already described to you.
Two is the pressure plate finger height. This is done through the hand hole in the bottom of the clutch housing.
Both of these adjustments only address when the clutch engages and disengages. Neither will fix a slipping clutch, if that's your problem.
