Re: Clutch Plate
Posted by D Slater on October 22, 2013 at 05:52:58 from (184.14.160.234):
In Reply to: Re: Clutch Plate posted by John G. Hasler on October 21, 2013 at 19:55:35:
Think that there was a test done on the type bolts that were used for that in the time period.
Will see if I can find it. Showed the bolts being below grade 5.
Most have a lifetime of pressure plate bolts installed without a torque wrench with some installed more than your answer and less than mine. So won't argue about what's the best.
544 is new enough to have the heads marked with the grade.
