Re: torque on oil pan bolts
Posted by Bob on October 22, 2013 at 09:31:42 from (64.255.159.192):
In Reply to: Re: torque on oil pan bolts posted by gene bender on October 22, 2013 at 02:28:03:
Torque for 5/16" tranny pan bolts using a cork gasket is typically spec'd at 13 to 15 ft. lbs. at the MOST, I wouldn't think a person would want much more on an engine pan.
