Re: 10-20 McCormick Oil Cups?
Posted by Nebraska Cowman on October 22, 2013 at 13:49:08 from (66.252.116.102):
In Reply to: 10-20 McCormick Oil Cups? posted by AaronWI on October 22, 2013 at 09:21:58:
exactly. The tall ones are the primers. If you are running the tractor on gasoline you probably don't need to use them but you might try it once to see if it starts better. Swing the top cover aside and turn the top half of the primer counter-clockwise a little to open it and then use a squirt oil can to add a little gasoline. You might want to take the primers off and clean them and make sure they are doing what they are supposed to. They are threaded on to short pieces of 1/8 in pipe. Sometimes the pipe will unscrew with the primer.
The short cups are to oil the valve train. Again use a squirt oil can filled with whatever lubricating oil you use in the engine. I think the instructions call for 10 drops daily or something like that. The oil goes into a trough with felt wicks to oil the rockers. Extra won't hurt anything. It will just run out the vent pipe onto the ground. At least that's the way it's supposed to work.
