Re: flasher relay location?
Posted by pete 23 on October 22, 2013 at 18:43:57 from (74.33.93.214):
In Reply to: flasher relay location? posted by nelson123 on October 22, 2013 at 15:59:36:
It should be on the left side above axle or some what forward of axle. If you flasher lights work but don't flash it may have been removed and wiring harness hooked together or it may just be unhooked and left out. Some states did not allow flashing lights so almost all IH tractors that came with flashers had a quick connector at flasher to bypass it.
