Re: 10-20 McCormick Oil Cups?
Posted by Janicholson on October 22, 2013 at 19:45:45 from (74.60.94.18):
In Reply to: 10-20 McCormick Oil Cups? posted by AaronWI on October 22, 2013 at 09:21:58:
If it is still tough to start, listen to the Magneto impulse coupling snapping, if no noise when hand cranking, the impulse coupling is not working. This would make it pretty easy to belt or pull start, but near impossible to crank start. Jim
