Re: Farmall 30 Power loader replacement hydraulic cylinder help
Posted by SDE on October 22, 2013 at 20:12:14 from (174.124.58.189):
In Reply to: Farmall 30 Power loader replacement hydraulic cylinder help posted by JohnnyMoto on October 22, 2013 at 09:31:06:
If the rams are used for pressure up, and gravity feed down, the shaft is not as critical as the internal surface and seals in the ram. If the seal is leaking in the ram, then some oil will most likely slip past the wiper seal on the shaft, but if the ram isn't leaking, then the pits and rust are only a cosmetic problem. Clean and polish to your liking.
Hope I understand this problem correctly.
SDE
