Re: trans fluid level
Posted by Jim Becker on October 22, 2013 at 21:12:37 from (173.57.153.141):
In Reply to: trans fluid level posted by ronztractor on October 22, 2013 at 19:15:31:
There is a level plug on the left side, more or less behind the brake rod. You can get a manual from Binder Books.
Here is an online copy of the Super A manual. That part (and most of the other lube instructions) is the same.
http://www.cleancomputes.com/Cub/Super%20A%20-%20Super%20AV/Super%20A%20-%20Super%20AV%20Owner's%20Manual/index.html
