Re: clutch question
Posted by glennster on October 23, 2013 at 10:35:29 from (76.223.247.94):
In Reply to: clutch question posted by Ed in Pa on October 23, 2013 at 08:21:41:
not real familiar with the 574, but often the clutch disc will "stick" to the flywheel if sitting over time. you can try blocking down the clutch pedal for a few days and then try rocking the tractor in road gear. this may get it loose. other options are spraying brake cleaner on the clutch and disc, either thru an inspection cover or by pulling the flywheel. or last resort, get the tractor in open country, start it in gear 3rd or 4th, and drive around holding the clutch down and applying the brake. or hook it to an implement like a plow and make a few rounds with the clutch depressed. it should break free.
