Re: IH 2 Bottom Plow
Posted by Lmack on October 23, 2013 at 11:05:01 from (24.131.50.165):
In Reply to: IH 2 Bottom Plow posted by Marion Watts on October 23, 2013 at 09:04:01:
You have a one point 2-14 plow with "Plow Chief" shares for a 100 through 140 (if I see the photo clearly). The points can be found but they are scarce. If you wish to replace the plows you will be forced to use a more modern version called "Super Chief" and they are pricy. Your plows are two piece with a solid wing and point and no shim. The "Super Chief" version will have a three piece set up and will include a one piece plow point as well as a shim. They will bolt right onto your frame replacing your existing plows and wear parts are readily available.
