Re: Identifying inheritance
Posted by Lmack on October 23, 2013 at 11:42:34 from (24.131.50.165):
In Reply to: Identifying inheritance posted by rray on October 23, 2013 at 11:17:31:
Did you say "engine serial number plate"? Was it mounted on the left side of the clutch housing? If it was a shinny metal plate then it was the frame serial number plate and there was only one on the entire unit. The motor serial number is to be found hand stamped on a flat on the right front side of the motor above the distributer almost behind the throttle rod.
