Posted by The tractor vet on October 23, 2013 at 13:10:11 from (75.19.125.100):
In Reply to: 706 Brake Valve posted by boomer22 on October 23, 2013 at 12:36:32:
Well in all the 706's that i have been into i have NEVER had to get into a brake valve . Now there is ALWAY a little leakage when you open the bleeder with the engine running BUT it is not enough pressure to apply the brake.Myself i think you have and adjuster problem . And now that you have played with the brake valve i have no idea what all you have done and not being able to look at it myself i am not sure where to tell you to go . Did you replace the return springs?? did you get it assembled correctly ?? did you work on the self adjuster and replace the spring clips?? is the self adjuster set correctly ?? If it was screwed up before are you sure that it was put together wright .Pictures need pictures or if ya ain't far from me then you need me to make a service call , but i am not cheap.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
