Re: discharge-hmmmm
Posted by Bob M on October 23, 2013 at 18:15:56 from (69.207.87.207):
In Reply to: discharge-hmmmm posted by rosedale123 on October 23, 2013 at 17:59:11:
If the battery ground cable was physically disconnected there's only a couple possibilities:
1 - The battery is worn out (it's discharging itself internally), or
2 - The generator is not charging. So when you last shut down the tractor the battery was already nearly dead.
Leaving the ignition switch on with the ground cable disconnected cannot cause a dead battery(!)
