Re: Super C rear wheel rim split - Ouch
Posted by AG in IN on October 23, 2013 at 18:55:49 from (67.236.118.56):
In Reply to: Super C rear wheel rim split - Ouch posted by ken_19 on October 23, 2013 at 18:36:18:
Unless someone "pimped your tractor", the rims should be steel, not aluminum. Some of the new replacements are a guage or so thinner than the originals, and the mounting loops will be welded on most new ones, not riveted like the originals.
No 24" stock Cub wheel/rim will ever fit a C sized tractor, and if you could make them work, it would make the tractor near worthless for most applications. Without drop housings like the Cubs have, you'll be dragging drawbar on the ground.
Before you junk it, see if someone is junking theirs. C/SC/200/230 should all have the same rims. Good used rims are out there. Tires too.
AG
