Posted by Janicholson on October 23, 2013 at 19:11:18 from (74.60.94.18):
In Reply to: 300 RC brakes posted by bigboreG on October 23, 2013 at 18:24:50:
The total cleaarance inside the housing, between the components and the friction surface at the differential housing is critical. It needs to be about .030" and .050" when the expander is fully collapsed, (not hooked to pull rod) with good springs and clean balls and ramps. this clearance can be measured with a caliper with the parts taken apart, or measured with shims to determine when a stack of shims locks the disks when the housing is tightened. More clearance than this allows the pull links and expanders to be so far from best angle that they do not apply proper force to the expander. To reduce the clearance the housing must be machined on its mating surface to close the gap. Even new disks will usually not be sufficient to get it working with wear on the housing, the expander's surfaces, and tractor friction surface. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
