Re: 300 Utility Hydraulic Issue
Posted by corona boy on October 24, 2013 at 10:26:34 from (169.204.239.38):
In Reply to: 300 Utility Hydraulic Issue posted by CowboyUp on October 23, 2013 at 20:56:44:
Also the tractors hydraulic oil is also the transmission oil. =hy-trans. Check that the pressure regulator is working on hydraulic side. if it isn't it will push oil hytrans right pass even a good seal. Voice of experience.
