Re: lo boy 154, 184, 185 info
Posted by mkirsch on October 24, 2013 at 16:07:07 from (64.80.110.75):
In Reply to: lo boy 154, 184, 185 info posted by chrisinsky on October 24, 2013 at 12:41:29:
8"? No.
I don't think the deck would cut that high even raised all the way up, and if it did it would not work well.
With the deck all the way up the front of the blades is higher than the rear, so you're cutting the grass TWICE, which takes twice the power.
They have about the same capabilities as far as grass type and cutting height as your typical riding lawn mower. They're just built better.
Around here, a decent one will set you back $2500+. For $750, you'd get a clapped out one that needed a lot of work, probably without a mower deck.
