Re: 300 Utility Hydraulic Issue
Posted by CNKS on October 24, 2013 at 18:21:04 from (216.144.104.128):
In Reply to: 300 Utility Hydraulic Issue posted by CowboyUp on October 23, 2013 at 20:56:44:
The seal alone keeps the oil out of the crankcase. As mentioned there is a groove in the shaft that needs a speedy sleeve. If it has a true seal be sure that the lip faces the oil, some have seals, some have orings, they both make grooves.
