I would pull the radiator and then the lower housing then with compressed air blow those passages clean then make up something to back flush with water then blow again. You can see them with a little mag lite. When you put the hose in the inlet you will see the water coming down thru them if you get them clean. Before removing parts mite want to drain and refil with vinegar for a little while that can also remove lots of junk. Whatever yu do when refilling make sure you use distilled water and Anti-Freeze
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
