Re: 300 utility full rpm = 1500 not 2200rpm
Posted by D Slater on October 25, 2013 at 05:04:25 from (184.14.160.234):
In Reply to: 300 utility full rpm = 1500 not 2200rpm posted by VWKarl on October 24, 2013 at 20:49:43:
If you adjusted the high idle speed in the governor housing and screwed the high speed stop bolt out some. Does the throttle linkage still move the stop bolt to its stop? If not check the linkage from throttle to governor. If so and you backed the stop screw out until the arm won't go anymore, get a new spring and try.
Above assumes everything else is set and working correct.
Don't know if you are going by the tachometer. If so double check it.
