Re: lo boy 154, 184, 185 info
Posted by tedregentin on October 25, 2013 at 05:34:13 from (216.110.201.79):
In Reply to: lo boy 154, 184, 185 info posted by chrisinsky on October 24, 2013 at 12:41:29:
I happen to own 2 cubs. Both are interesting little tractors. Both have good and bad points. My '62 with a loader and one point gets used every day, it seems like. My '72 lowboy 154 has a single blade belly mower. I recently purchased the '72 not running for $500. It had clutch issues, and needs a wiring harness. The clutch in the 154 is not a real good setup. I was able to repair mine without spending a lot of money. If I hadn't had the ability to do some fab work on the clutch, I would have needed to replace the complete clutch and the input shaft on the trans. All of the clutch parts are available, but can be expensive. I have only done a little mowing with mine,but it seems to do good job, with the mower all the way up or down. The three speed trans does not offer enough speed options. I understand that a high-low setup is available that can be added on, but I haven't seen one. If you have the ability and knowledge to do your own repairs you should be fine with a 154.
