Re: 300 utility full rpm = 1500 not 2200rpm
Posted by The tractor vet on October 25, 2013 at 07:05:14 from (75.19.125.100):
In Reply to: 300 utility full rpm = 1500 not 2200rpm posted by VWKarl on October 24, 2013 at 20:49:43:
Ok here goes, (1) check for any loose linkage , from the lever all the way to the Gov. And fix it (2) remove the Gov. cover and look where the spring hooks to the two arms , Does the spring just flop around in the arms?? . IF it does then the bushing are long gone as the spring is suppose to fit with vary little slop . (3) your spring may be getting weak or stretched You should have speed increase with in one notch of throttle movement . And full RPM's by the last notch . I went thru this on a friend's 400 and he is hard headed SOB as he did not believe me till i showen him the difference between his Gov . and my Gov. on my S/MTA even though mine is a M & W verse's his Stock one his bushings were gone and his would not ideal down or even come close to full throttle even with the throttle lever pulled down past the stop . I fixed it one afternoon for him and it made a new tractor out of it . So pull the sheet metal and the side cover back off and study every inch of the linkage and where the spring sets .
