Re: 240 battery drain revisited
Posted by Janicholson on October 25, 2013 at 14:52:45 from (74.60.94.18):
In Reply to: Re: 240 battery drain revisited posted by Fudd on October 24, 2013 at 15:38:07:
It should be Positive ground as stated above (or below). There will be a wire connecting the starter switch (either a round can relay or a rod and pull lever switch) to the electrical box. The wire connects inside to the amp meter. (it should be the only thing attached. The light switch should be connected either to the voltage regulator L terminal, or the other terminal on the amp gauge.
The ignition push pull switch (or key) should be connected to that same amp gauge terminal. A 4 to 5 volt draw would either be lights or at least make heat. Jim
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
