Re: Fast Hitch Setup for Plowing
Posted by Janicholson on October 25, 2013 at 15:05:53 from (74.60.94.18):
In Reply to: Fast Hitch Setup for Plowing posted by Don Hopf on October 25, 2013 at 08:13:43:
A 400 has either a front implement pitch control cylinder on the Fast Hitch front connection point (under the middle of the tractor), or it has a rude ementry Draft control system with a "D" handle on the left side of the platform that has notches in it to adjust draft pressure. The Draft control system is pretty much bogus. (Ours was always in the highest notch handle up) The pitch control was best as it allowed the Fast hitch to be adjusted for the angle of attack of the plow. Lowering the front of the hitch made the plow suck into the ground easier, raising it made it dig in less. The plow may be small for a 400 as it is a 3-16 in clay or 3-18 in loam. The adjustment of the wheel position should be so the first moldboard is its width away from the furrow. Jim
