Posted by caterpillar guy on October 26, 2013 at 04:15:19 from (75.128.156.3):
In Reply to: 4100 shifting issues posted by D1206 on October 23, 2013 at 08:57:48:
Cover can be machined for a bushing. The pivot is replaceable and then if the reverse fork is not worn or the key loose it should work fine unless the problem has ground the teeth off to the point it will not engage. The cam could also need replaced. Yes they work the same as the 4166 which is like the 06 series. If one of the rollers is missing it will act that way also.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
