Re: 300 utility full rpm = 1500 not 2200rpm
Posted by VWKarl on October 26, 2013 at 09:49:44 from (207.216.93.179):
In Reply to: 300 utility full rpm = 1500 not 2200rpm posted by D Slater on October 26, 2013 at 08:04:37:
Yes I have done that according to the manual. The upper bolt (10) just resting on the engine block at idle speed and the lower bolt (11) just resting on the engine block at high idle speed. Also synchronized the throttle butterfly with governor by removing the top slanted cover plate and the pin and shaft in there. Mine was actually out 3 turns on the block. Great picture by the way. Although slightly different than mine. I can see that my spring is not as heavy duty as yours. So I'm thinking the PO has gone to the hardware store and improvised . I am going to try and shorten it up like rankrank1 was saying until I get the new one.
Great site by the way I've been coming here for years and never found the need to join as I got all my answers by just searching.
Karl
