Re: Ignition Switch
Posted by CNKS on October 26, 2013 at 19:45:58 from (216.144.104.128):
In Reply to: Ignition Switch posted by Dave8N in Pa on October 26, 2013 at 17:01:13:
Provided it is the original switch, in is off and out is on. If it has a magneto the switch (in) grounds the mag and has only one wire, if it has a distributer it has two wires. It is possible that the starter was ok. The connections to the cables or the cables themselves may be corroded, check that also.
