Re: INTERNATIONAL 10-20
Posted by Nebraska Cowman on October 27, 2013 at 04:03:21 from (66.252.116.102):
In Reply to: INTERNATIONAL 10-20 posted by F30 on October 26, 2013 at 17:56:26:
Look down in the hole with a light. I think you will find the holes in the tubes correspond with the galley in the block that connects to the vent pipe. It lets oil from the head / valve train drain out. Oil from the valve train does not go into the sump. Valve levers are oiled by hand through the oil caps on the valve cover.
