Posted by Janicholson on October 27, 2013 at 18:19:01 from (74.60.94.18):
In Reply to: Re: Ih 460 posted by Farmall tom on October 27, 2013 at 13:06:30:
I need to know (to assist you) what happens in the following circumstances: Starting in 5th gear with the TA handle rearward, 3/4 throttle let out the clutch on a smooth level field road_________________________ Pulling a mold board plow in variable ground in 3rd with TA handle forward. The tractor slows, you pull the handle back quickly, ______________________ You pull up onto a slight grade leading into a barn door in 3rd, TA ahead, and push in the clutch. you stop and try to rake it out of gear. Answers to these will help. If when the lever is pulled rearward the tractor just plane stops, you are going to need a ramp and rollers (one way clutch) at least. It requires a double split to do the job. at the clutch to engine, and at the back of the clutch housing to transmission. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
