Posted by gene bender on October 27, 2013 at 19:03:22 from (207.177.56.213):
In Reply to: Farmall 230 clutch posted by RandyM on October 27, 2013 at 14:14:39:
That clutch and pressure ;late is not your peoblem But you do need to go thru the linkage making sure throw-out bearing and the yoke its mounted in is not bent,holes worn or otherwise in bad condition. Now is the time to replace the pilot bearing in the crank and probably your thro-out bearing is shot. Make sure the yoke assy holding the thro-out bearing is not bent. Also the tube the thro-out bearing rides on it not loose and still fastened to the bell housing its a press fit but your pressure plate needs a good cleaning on the surface also the fly-wheel on the crank probably needs cleaning also maybe resurfacing a little do not remove anymore than needed to clean it up. Sometimes just a good sanding will make it nice and shinny again.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
