Re: Light switch
Posted by gene bender on October 28, 2013 at 10:40:53 from (207.177.56.213):
In Reply to: Light switch posted by Ronztractor on October 28, 2013 at 05:08:14:
The original one did have the resistor at the bottom of the sw thats for hi-charge and the wire from there goes to the F terminal on the gen. Your gen should have the last three #s either a 355 or 423 and they have an adjustable third brush set for charging amount. When the sw is in the hi-charge position it will charge more. If you need an original i do have some as replacement sw you see listed arent like the original and probably will not work like the system was meant to operate.
