Re: Ignition Switch
Posted by Dave8N in Pa on October 28, 2013 at 16:37:20 from (24.153.44.140):
In Reply to: Ignition Switch posted by Janicholson on October 26, 2013 at 17:01:13:
Quoting Removed, click Modern View to see Thank you Jim, That's a lot of help. The shut-off valve seems to need work and I think I'll take the carb apart as soon as I can get some gaskets. The manifold is broke and I don't know how long it's been run that way. I have been told that's a good way to warp exhaust valves so I'm going to check the compression first. But it didn't pop or puff when I ran it. I have a lot to do but I will follow up when I learn more. Thanks for the help!
