Re: C 153 out of 504 into super
Posted by steve il on October 28, 2013 at 17:35:51 from (50.103.191.191):
In Reply to: C 153 out of 504 into super "C" guestions posted by farmallstrong on October 28, 2013 at 15:20:51:
farmallstrong said: (quoted from post at 23:20:51 10/28/13) I think the 504 bellhousing is different. You need a power unit from a combine. The crank needs drilled for the pilot bearing,and I think you have to cut some off the input shaft. Also you will need to deal with the radiator hook up.
farmallstrong is correct on all this
you can put a pilot bearing in your flywheel thats why you cut off the input shaft. that way you dont have to take out your crankshaft.
This post was edited by steve il at 17:38:57 10/28/13.
