Posted by D Slater on October 28, 2013 at 20:21:03 from (184.14.160.234):
In Reply to: ring and pinion help posted by Taylor88 on October 28, 2013 at 19:06:15:
460 Farmall? international? or high utility?
Farmall and high utility pinion shaft 15 teeth, 460 and 300. Utility 300 16 teeth. International 460 18 teeth. Ring and pinion change can be swapped into those tractors by changing both gears. But depending on the models, you can end up with different ground speeds.
Yes the 300 U set will work. Ground speed will be faster if installed in a farmall and slower if installed in a international 460 regular utility type.
This post was edited by D Slater at 03:47:43 10/29/13.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
