Re: ID Please
Posted by Lmack on October 29, 2013 at 17:39:42 from (24.131.50.165):
In Reply to: ID Please posted by jgstrickland on October 29, 2013 at 09:29:27:
This is a universal planter hopper mount and I do not know if it was for an A or Cub. The mounting surface has been welded up so it is not original. By changing out the box drive cog on the top different planter boxes could be used including rotating bottom boxes. IH had at least three planter boxes including the two plate box described by someone else and two different rotating bottom boxes. One was specifically designed for non delinted (fuzzy)cotton seed.
