Re: farmall200
Posted by dewy on October 29, 2013 at 18:26:37 from (72.145.215.42):
In Reply to: farmall200 posted by dewy on October 29, 2013 at 16:46:06:
i remember that on the first one it was gone i wiped it out good i seen metal,, i will pick at it make sure its metal,,but i think it is ,,,, that washer is so thin like the cover thin, if you coc it at all it pinches out ,,why does the bolt feel like its got a rough spot in it if u keep the cover still ,if you let the cover spin , with bolt kinda threads on to cover.if u keep cover still after tight spot while tighting, bolt kinda pops loose then its easy ancovers more free feelin and will screw in,and theres where u have to make sure your dead ontop of it ,,,seems like it should be deeper in housing, thicker washer something...dewy thanks ya
