Re: gas to lp conversion
Posted by Heat Houser on October 30, 2013 at 14:29:51 from (69.66.35.73):
In Reply to: gas to lp conversion posted by 1968 403 on October 30, 2013 at 06:04:58:
This is memory so...
The lp head had stellite exhaust valves and seats. Reduce the time between valve lash adjustments if using a std head.
The distributor advance curve was a bit different as well, along with the timing setting.
High compression pistons
Exhaust and intake manifolds totally separated.
All that I can think of right now.....
