Posted by Russ600 on October 31, 2013 at 18:32:12 from (162.212.68.75):
In Reply to: gas to lp conversion posted by 1968 403 on October 30, 2013 at 06:04:58:
Hi.
I did a lot of lp conversions over the years in pick ups. Mainly big block Chev. and Ford, and I always had good service with Impco kits. IH had those engines with factory lp so I would use their spec for the timing. If your engine has valve rotors I would take then out as propane is a dry fuel. As far as changing valves at the time of the converation, I would hold off until it starts to give trouble. I have run some big blocks chevs over 100,000 miles before I did the heads. If the head has been overhauled since unleaded gas was the norm it may already have better valves and seats which last pretty good. Also use the IH spec for the spark plugs, generally propane engines require a hotter plug. I go along with the 10% loss in power but it makes up for it with the savings in fuels costs. Cheers Russ
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
