Posted by Brian Schmidt on October 31, 2013 at 19:35:19 from (69.66.237.150):
In Reply to: Gear oil for super c posted by Sgtmajpy on October 31, 2013 at 19:19:54:
You will be fine with 85w-140 in the summer. I like the thicker oils as they can take more gear pressure. It also allows the gears to slow down faster when you press in the clutch from neutral. If you operate much in the winter, you may want 80w-90 though.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
