Posted by David Lampman on November 01, 2013 at 08:05:03 from (69.54.29.239):
In Reply to: Cracked block repair posted by David Beasley on October 31, 2013 at 08:32:34:
My super A was cracked in exactly the same place. I tried JB weld with no luck. I Ved the crack and let it set for 3 days. About 5 hours of off and on running and the crack came back right in the middle of the JB weld. I thought, well maybe I didn't use enough JB weld so I ground out the JB weld and started again. Same result. I think the differences in the expansion and contraction rates between the JB weld and the cast iron was different enough to cause the crack to form again. I ended up replacing the block. To me, that is the only real fix.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
