Re: Milling brake casting on 450
Posted by rhtx55 on November 01, 2013 at 16:40:22 from (68.185.207.25):
In Reply to: Milling brake casting on 450 posted by Hugh McKinney on October 31, 2013 at 08:08:54:
I just did mine on my F300, and one side was very rusted. I took all the parts to a machinist and had him mill the inside brake surface in the housing flat, and mill the two actuator discs brake surfaces flat. The brake surface on the rear end housings only needed .005 milled off to clean them up.
I purchased new brake discs (4), balls (6), and springs (4).
Now watch it on the springs, some have the openings on the same side, originals were open at 180 degrees, these are the ones you need to purchase. I tried the first ones with the openings (hooks) on the same side and had no luck with them as the brakes kept binding.
Clean up the inside ( where the balls go) of your brake actuators via media blasting or rotary wire brush, pay particular attention to the ramps the balls travel in. These must be clean with as little material removed as possible. Mine were not pitted, and cleaned up well with a wire brush, I then used emery cloth to polish the ramps shiny and used copper never seize to coat the new balls & ramps, once you have the actuator halves assembled, with the new balls & springs, take your brake housings and lay them on the work bench.
Install the first brake disc. Check to be sure the actuator is fully compressed, and the balls are fully seated in their pockets.
I measured mine with a dial caliper to be sure the measurement was pretty close all the way around. Now install the assembled actuator and the other inside brake disc. Place a straightedge across the mounting face of the brake housing and measure the clearance from the straight edge to the top brake surface.
I have found .030 to .040 is about optimum for the clearance.
The difference is how much your machinists need to remove from the outer housing surface to achieve the .030 to .040 clearance. Any more than that the brakes don't work as well as they should, any less and they stick & grab and you always have to back up to get them to release.
There is a large oring that seals the inner brake surface to the rear end housing, you will need 2, and a seal that goes on the pinion shaft you will need 2 also. Check the teeth on the pinion shaft the brake "pads" ride on. If they are very pitted or worn the brakes will stick no matter how much never seize you use.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
