Re: Brake locks up B 450
Posted by J. Klein Rot on November 02, 2013 at 08:23:08 from (84.80.14.225):
In Reply to: Re: Brake locks up B 450 posted by David G on November 02, 2013 at 08:13:26:
When i replaced the discs i was dry in the brake housing.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
