Re: marks in cylinder bore
Posted by Janicholson on November 02, 2013 at 18:32:04 from (74.60.94.18):
In Reply to: marks in cylinder bore posted by Steve43 on November 02, 2013 at 18:26:17:
Sleeve it as is. If the sleeve is very tight (won't go in more than 1/3 of the way by hand at normal temps, I would hone the bore to let it get 2/3 of the way in, then Chill the sleeve, and warm the bore before setting to depth. Jim
