Re: Super m wiring - won't shut off
Posted by rvirgil_KS on November 02, 2013 at 19:45:25 from (192.208.170.188):
In Reply to: Re: Super m wiring - won't shut off posted by Brady miller on November 02, 2013 at 07:13:19:
Any diode 1.5 amps@50 volts or greater will work. Radio Shack 276-1661 has good heavy leads.
A diode passes current in one direction, blocks it in opposite direction. The amp rating is the amount of amperage it will carry without breakdown. the voltage rating is the reverse voltage it will withstand without breakdown. Anything higher than above ratings gives added reserve.
