Posted by richardinnz on November 03, 2013 at 02:34:22 from (222.153.154.60):
In Reply to: Brake locks up B 450 posted by J. Klein Rot on November 02, 2013 at 07:35:00:
If it is possible to do so drive the tractor in 2nd gear and press the brake pedals, pressing more and more firmly and heat the brakes up, sometimes this will cure it, or if the brake locks that bad that you can't do this you will have to dismantle, clean, remove any burrs from the sliding surfaces between the expander and brake housing, check the balls, ramps and springs are in good order, deglaze the linings lubricate and reassemble. Best to use this type of brake hard and not lightly and often. Same problems occured with Leyland/Nuffield, Belarus and Massey '65s which had the same sort of brake.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
