Re: valve job on a 47 Cub
Posted by gene bender on November 03, 2013 at 07:03:50 from (207.177.56.213):
In Reply to: valve job on a 47 Cub posted by charlie M on November 03, 2013 at 06:35:38:
Remove the head and valves then you can see if the seats need replacing. If they need replacing the block will need to be removed. Find some help from someone who can tell you.
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
